Hello All,
I recognize this may be more of a SQL Server issue, however I was wondering if anyone has dealt with the following:
I have a need to change some SQL Server configuration settings in our batch load via a sp_configure statement. Calling the stored proc in a script object during the load is my best bet.
Unfortunately when I try to issue a RECONFIGURE command to set the changes I get the following error:
“CONFIG statement cannot be used inside a user transaction”
sql(‘DS’, 'EXEC sp_configure ‘show advanced options’, 1);
sql(‘DS’, ‘RECONFIGURE’);
I have also tried to embed the call to this sp_configure and RECONFIGURE in another SP I created however that will not run either.
If anyone has a workaround I would appreciate it! Stumped.
LucaBrasi23 (BOB member since 2008-09-15)
