system
April 11, 2012, 7:23am
#1
Can we create a script to disable user accounts in CMC who do not accessed BO reports in Last 30 days.?If it is possible can you please send me the script.
kishore (BOB member since 2003-02-03)
system
April 16, 2012, 9:12am
#2
Can any body please give me quick solution for the above question?
system
April 16, 2012, 9:49am
#3
Found these on searching
I am using BO XI R2 .NET SDK. From my web page I want to Enable/Disable user account in Business Objects. I know business objects will automatically lock the user if the user enters an incorrect for x times. If the user is locked or disabled, I want to enable it from my web page instead of going into BO Console. I was able to add/delete the user but not enable/disable the user.
Please let me know how I can accomplish this?
Thank you
Here is a little excel file with a bit of VBA code to extract from a CMS the complete list of user and the list of groups each user is member of. Quite useful when you need to check group membership
Its now possible to edit the CMS data, simply by modify entries in the Excel File. You need then to export your modification back to the CMS. Modifiables column are : Login, FullName, Email, Disabled and Description.
Platform: BO XI R2 / BOXI3.1 (it’s necessary to change the libs to fits XI3.1, s…
haider (BOB member since 2005-07-18)
