I would like to know how can I do to refresh and save in .xls a report every morning with VBA for example without using the BCA… ?
In BO I know that we can use VB.
go_ahead (BOB member since 2007-01-13)
What is your reason for not wanting to use BCA
Carl Bell (BOB member since 2007-10-15)
My administrator doesn t want to use the BCA…
I’m obliged to found a solution to my pbm…
Somebody could help me please.
Here is a script that may help. You can set the document to refresh on open, but you will have to manually open the report. For OutputDir, type in the UNC location to save the report.
Public Sub Document_AfterRefresh()
Application.BreakOnVBAError = False
Application.Interactive = True
Dim Rpt As Report
Dim OutputDir As String = "\\unc_path\..."
Rpt.ExportAsExcel (OutputDir & Rpt.Name & ".xls")
End Sub
Carl
I would like to know how I can open, refresh and save a report in xls file,
automaticaly by VB please.
The user would like this kind of refresh…
Thanks…
You could try scheduling a batch script to open BO and call the report with the VBA script. I have never done this before.
Actually, it would be much simplier if your administrator would let you use BCA.
Here is the batch script:
The first line is the directory where BO is installed.
The second line is the report to open, security domain, username, password. the user will have to be granted VBA priviledges in Supervisor.
@echo off
“C:\Program Files\Business Objects\BusinessObjects Enterprise 6\bin\busobj.exe” -online
“C:\ReportName.rep” “Domain” -user “username” -pass “password”
Hope this helps.
Carl
Carl thank you for your help it works,
But I would like to refresh and save in .xls the report,
how can if I want to group all this fonctionnality in a batch file or vb file ?
Edit and place the VB script (Tools > Macro > Visual Basic Editor) I gave you in the report you want to refresh and export as an .xls
Set the report to Refresh on Open (Tools > Options > Save > Refresh Document When Opening). Use the batch script I gave you to call the report.
Make sure there is no input prompt in the report.
Carl Bell
[Moderator Note: Moving from BusinessObjects Classic forum to SDK]
Thank you for the script but I have an another question.
When I launch the script (to open BO), I have to click on “ok” …
I would like to know if there is a possibility in the script to valid the username and pwd without cliking on ok ??
Append this to the batch script for invoking BO
-Nologo -Blind
haider (BOB member since 2005-07-18)
Sorry but I’ve put the macro on VBE, and when I launch the batch file …
It doesn’t create the xls file and doesn’t refresh the report…
How to have an exportation automatically ?
I replied to this
Paste the final script where the XLS file and refresh is not happening
Delete the previous script and try this one instead:
“C:\Program Files\Business Objects\BusinessObjects Enterprise 6\bin\busobj.exe” -user userID -pass password -online “C:\filename.rep” -keyfile “domain” - nologo
For That :
"C:\Program Files\Business Objects\BusinessObjects Enterprise 6\bin\busobj.exe" -user userID -pass password -online "C:\filename.rep" -keyfile "domain" - nologo
=> It works.
The report was opened but, it doesn’t refresh and not save the xls file…
ThisDocument.Refresh
ThisDocument.SaveAs ("C:\.....")
End Sub
Why ???
the batch file work, the logon is ok but not the refresh and the save…
thanks…
This macro did not work?
Dim Rpt As Report
Dim OutputDir As String = “\unc_path…”
Rpt.ExportAsExcel (OutputDir & Rpt.Name & “.xls”)
End Sub
Carl no it doesn’t work … ?
Do I have to add some librairies ?
Or is there an other way to run automatically a macro ?
In fact it works only when I execute by myself the macro,
but automatically => no … what’s wrong. I’d never use macros on report
help me plz.
End Sub
For the above code to work the document has to refresh on its own when called from batch file.
To do that set the option ‘refresh document when open’ from tools->options->save.
Also remove the thisdocument.refresh, just keep the code for save in XLS.
Remember that when invoking a document from batch program you will have to do an application.quit else the application will be active in the background. So add it too in the code
