I have a script which passes a value of 04 to an @prompt called “END”. When I submit this script to DAS, I keep getting “Unable to refresh document!”. All of my secured commands are active. This script name is End 04-April.SPT. Here are the contents of the script: Sub Main
dim doc as BODocument
Application.Variables.Item (“End”).Value=“04” set doc=ActiveDocument
doc.refresh
End Sub
Does anyone know why this script fails? BTW, BusinessObjects 4.1.1 on Rdb 6.
Best regards,
Crystal Golding
Senior Systems Analyst
Management Information Section
University of Queensland
Brisbane Australia 4072
E-mail: c.golding@mailbox.uq.edu.au
Web: www.mis.jdstory.uq.edu.au
Phone: +61 7 336 57289
Fax: +61 7 336 58202
