BusinessObjects Board
Scorecard Alerts as of Percent
I am using Dashboard Design 4.0 I have a scorecard which shows Prior, current Plan forecast data…
My data looks like this
how can i show the Arrow alerts on current column as percentage of plan…
I selected Current column and then as percentage of Target…
then selected Plan column as Alert Values and Current column as Target Values…
All I am getting is Green Arrows… I mean I am not able to understand how it works… For prodb I should see yellow…
any help…
rajx72 (BOB member since 2006-08-02)
I think you may have selected the values backwards.
The Alert values should point to your Current column. The Target values should point to your Plan column. Then, with the Color Order set to ‘High Values are Good’, adjust your Alert Thresholds so that the arrows change according to your thresholds. For example, for ProdA to show as yellow in your example, the Green threshold would have to be set to about 95% for your values.
Hope this helps,
~RoxanneP
Sr BI Consultant
Infosol
RoxanneP :us: (BOB member since 2006-08-07)
