I need to schedule WebI reports every week and send it to some common network drive(for ex. D drive or E drive in our common network)
I can see only 3 different types of destination on CMC under schedule: Default, email(SMTP) and Inbox. I would like to schedule our BO WebI XI R2 report every week and send it to our common network drive. Can anybody please advice me how can i do this.
I have tried to schedule Webi reports from Infoview. I am admin so i have rights to schedule from infoview.
Under Destination option i have seen list of options. Our requirement is to send our webi reports in pdf format to our common shared network drive. Should i choose “Specific file location” for this purpose? i tried with this but my job failed. There are some default location also. how can i configuare my system to use those default location?
You need to configure the webi servers to support the Unmanaged Disk destination.
In the CMC go under Servers, choose the WebI Job server, and look under the Destinations tab. You’ll see that Unmanaged Disk has a big red bar through it. Enabale it ad then go make any changes to the default settings that you want to and save. Do the same thing for the Webi Report server.
If you use the Crystal Reports doc type then you’ll need to go configure the ReportJob, ProgramJob, and DestinationJob servers as well. If you use DeskI then those servers will need to be configured, and if you use RAS you have to do that one as well.
I have enabled Unformatted disk setting on destination tab. I have to schedule my BO reports and send it to some folders inside J:. So the path i gave under Destination Directory is J:/Folder1/Folder2/Folder3. But i am getting error: destination directory error.CrystalEnterprise.DiskUnmanaged: No such file or directory
Am i doing something wrong here. Please suggest me.
Don’t use drive letters. Use the full universal path ( \servername\volname\directorynames\ ) in case your maps are different from the acct you’re rnuning the server nuder. Also, don;t use the Local Admin account to start the server. Change it to a domain account so it has some rights on the network.
Is it possible to send the report to a different folder within the Webi / BO environment ?
I need to create an archive of monthly snapshots, so once a month I want to copy reports run the report sand send them to a Sub folder with the Month name
When I put \servername\folder name in the unmanaged disk in CMC for deski job server, it changes it to forward slash //servername/folder and I dont see the file in the folder.
Do I have to put the account name at the bottom, the shared location has no security and can be accessed from the server.
Yes, you have to enter the credentials of a domain user. Even if the network share is open, it will not accept a connection from the Local System account.
You can set the credentials either in the job server or the individual report.
HI - I’m curious - regarding sending reports to a file location… has anyone ever set up the server (enabled the unmanaged disk), scheduled a job (which worked fine), and then went back oh say the next day to do it again and that option disappeared from list of destinations?
This is happening to me… i enabled the ability to send to a specific file location and set up one scheduled job. I then went back later (like 4 hours later) to schedule another job and the option was gone from the menu… i went to CMC and doubled checked settings… all are still intacted…
Good Lord - I didn’t understand that from prior posts in this string… tried and it worked… i would think you’d put format before destination if that’s what determines which destination types are available…
