I have a SharePoint path as -
https://xxx.yyy.zzz.com/sites/.../…
that I need to convert to a UNC path in the scheduler for a Webi report. If I use the above format it gives a source file error. I have tried to convert it using forward slashes only and it runs successfully, but it will run whatever is put in the path.
I need to know the path is correct before I start investigating other possibilities for failure. Is there a standard format for converting http paths to UNC?
BOE 4.1 SP5
frank35
(BOB member since 2005-08-25)
I don’t understand.
joepeters
(BOB member since 2002-08-29)
for example I believe the ‘correct’ path is /xxx/yyy/zzz/Sites/… but I could put any other character in such as /xxx12/yyy34/zzz/Sites/… and it will still say it’s successful when the path is obviously made up.
The scheduler doesn’t seem to like “.” in the path hence why I want to convert the http:// format into a UNC path with ‘/’ only.
frank35
When doing a similar thing I found it would actually create folders on the fly to match what you specified…if there was a temp folder but you specified /temp/this/that…this and that would appear as new folders!
Nick Daniels
(BOB member since 2002-08-15)
