Scheduling reports
Is it possible to set-up scheduled reports so it runs and emails report only if there is data? Otherwise report should still run but not send an email when there is no data. Can this be done using scheduling?
Thanks in advance
Stara
stara (BOB member since 2005-12-02)
[Moderator Note: Moved from WebIntelligence XI to XI Scheduler]
No… you can’t. A custom utility is required to do the check and send an email.
Where would I get more information on custom utility for this?
Theres a couple of methods discussed here:-
https://bobj-board.org/t/99674
