Scheduling Question
Hello,
I have scheduled several reports to run at 6:30am every day. It appears that they are running, because the number of instances increases by 1 every day. The problem is when I open the report, I seem to not be viewing the latest instance. Is there a property where you can set the report to automatically open the latest instance when users open the report?
Thanks for the help.
jmfuller (BOB member since 2010-02-16)
Solution:
CMC > Applications > InfoView > Properties >
Default Viewing Action on Listing Page:
View the object
View the latest successful instance of the object
However, this blew out the hyperlinks in the Universe
Setting the Default Viewing Action to View the latest successful instance of the object will by default display the latest instance of the report on open. However, reports that are not scheduled (and thus do not have instances) and hyperlinks will no longer open with a double click. To open these, you need to right click and select View.
We spoke with BO on the phone and they told us that this is just the way it is.
