system
January 23, 2012, 8:46am
1
Hi Team,
I have scheduled a report on daily basis.
My requirement here is that if there is no data in the report it should not be scheduled and if there is data it should be scheduled.
Is there any option to do this…?
Im On BOXIr2Sp2
Sai
saikrishnag21 (BOB member since 2011-02-10)
system
January 23, 2012, 10:13am
2
You can find out whether a report returns data or not by refreshing it.
Since you have already mentioned its scheduled it will run anyways.
What are you trying to achieve here? do you want to stop sending deliveries of the scheduled report if it has no data?
jprasanthram (BOB member since 2010-12-10)
system
January 23, 2012, 10:26am
3
Hi Prashanth,
Thanks for the reply.
Yes i want to stop sending deliveries of the scheduled report if it has no data.
Sai
system
January 23, 2012, 12:30pm
4
Take a look here:
We schedule some webi reports and send out the reports by email. Sometimes the reports do not have data return. Are there any methods to generate emails that only the reports contain data?
Please give some advices
many thanks.
jiang (BOB member since 2007-01-12)
HTH
mcnelson (BOB member since 2008-10-09)
system
January 24, 2012, 10:22am
5
Hi mcnelson,
Thank u very much…it worked…
Sai
