system
1
Scheduling Lumira Designer dashboard failing. (Object failed to run to an error while processing on the Job Server.
Lumira Designer scheduling Lumira Designer dashboard failing all the time.
I am able to schedule Lumira Discovery with no issues using LUM format.
victoreasaw (BOB member since 2018-12-07)
system
2
I have also this issue.
Did you find the solution. Or anyone?
Running 4.2 SP6 with Lumira 2.1
Björn
Bjorn
(BOB member since 2006-02-10)
system
3
Still not able to schedule Lumira Designer 2.2
system
4
Victoreasaw, It seems like we are the only ones facing this problem!
I have followed SAP note 2620775, but the issue remains regarding the jobserver.
Any input is valuable.
Kind regards
/Björn
Bjorn
