BusinessObjects Board
Scheduling in Xcelsius
I want to know whethter we have the facility of scheduling in Xcelsius? I got a requirement like “subscribers” in xcelsius, for this I need to have the facility like scheduling. Is this possible in Xcelsius?
nanda p (BOB member since 2014-06-20)
Welcome to B:bob:B!
I’ll move this to the Xcelsius forum for you…
What exactly do you mean by “scheduling”? More particularly, what would you be delivering?
If you just want to alert people that there has been a change in data (i.e., end of month processing is complete and ETL has run), set up a simple schedule on a WebI report that lets the “subscriber” know and includes a link to the dashboard.
I think you can also set up a schedule on the SWF file stored in the BOXI repository. So you could send a shortcut to all the subscribers inboxes.
If you want to actually distribute the SWF file, that is probably a bit trickier. You’re probably better off setting up a reminder and doing it manually. But, I also seriously question the wisdom of emailing the SWF file around. That is definitely not going to be an optimal solution.
