Scheduling Docs from WebI
We currently have WebI and BCA installed on separate servers but not in a cluster configuration. I can schedule documents fine from the full client, but when I try to schedule from WebI I keep getting a WI0202 error indicating that the WIGenerator is not installed or is not activated.
I assume this is because WebI and BCA servers must be clustered or on the same server in order to schedule documents from WebI.
Can anyone validate this assumption?
Thanks, Jeff
Jeff,
you have to install the WIGenerator module on the server where BCA is running also. The two machines do not have to be on the same cluster (same OSAgent port).
ioannis
Jeff Kitzman jeff.kitzman@DOT.STATE.WI.US 04/18 12:01 PM >>>
Thanks, Jeff
It is not neccessary to have BCA and WebI on sasme machine (it is not realistic too), not even same cluster.
But you need WIGenerator component on BCA cluster, I think that’s what you are missing.
Vasan
jeff.kitzman@DOT.STATE.WI.US on 04/18/2000 12:09:19 PM
Thanks, Jeff
******************************************************************************* Note: The information contained in this message may be privileged and confidential and protected from disclosure. If the reader of this message is not the intended recipient, or an employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us immediately by replying to the message and deleting it from your computer. Thank you. Ernst & Young LLP
