Hello friends, we are having a strange problem with our scheduled reports on Crystal Server XI R2. If the report is scheduled between midnight and 1am it simply stays in “pending” status and never comes back from there.
The following topic talks about this issue a bit:
I wonder if anyone has run into this or found workarounds more recently.
I had this exact same issue in Business Objects XIR2
I noticed that a job scheduled between 00:00 & 01:00 would stay in Pending for 23 hours & then run
You can verify if this is the same for you by querying the CMS database through the Administration Launchpad tool “Query Builder” & query the report instance that you created & look for the value for SI_STARTTIME; in my case it was 23 hours later than expected & this is the time the report will run
The issue was resolved in CHF14 (although in the release notes there was no specific mention of a fix for this issue - it may have been a side-effect of another bug fix)
