I am rescheduling a report (CMC - instance manager) and all I need to do is change a prompt value. I do this and submit but when I go back in to check, the value has re-appeared. Is this a known issue?
Obviously I can reset the whole thing from scratch and create a new schedule but would rather not.
BOE 4.0 SP3
thanks
frank35
(BOB member since 2005-08-25)
Probably a bug. You are running a very old patch level of BI4.
You can research the bugs, using the links here:-
https://bobj-board.org/t/212450
Mak 1
(BOB member since 2005-01-06)
sorry, it’s SP5.
frank35
Well, you should have a look through those links. I’m pretty sure I have read about this issue before.
Mak 1
Ok, thanks. Strangely enough double clicking on the schedule shows the amended (correct) prompt values. It’s only when I go in to ‘reschedule’ that the old ones appear. May even have something to do with the values being set as default in the report itself. I’ll take a look.
frank35
Yes I had this issue before with BO 4.0 SP4. It has been fixed in a more recent patch but I can’t find the SAP Note related to it.
Do a search on the SAP BO website it shoud be easy to find.
Yvon
Yvon P (BOB member since 2006-04-27)
