schedule same report with multiple values for prompt
I have Webi and Deski reports that need to run monthly for 100+ client. Each report needs to be expored as a PDF. Instead of scheduling the report to run monthly for each individual client (select with the prompt), is there a more efficient way through the CMS or InfoView to complete this task? I understand we can use a macro for the Deski reports, but was hoping there was a way through InfoView.
To make sure this is clear, report 1 has one prompt for the client and we need to produce this report for 100 clients.
T
TMullan :us: (BOB member since 2007-03-08)
Do a search for publications or bursting (a publication is used for bursting). Bursting allows you to refresh a report once and then split it for each unique value for some variable. Functionality differs based on the version of XI you are using.
BoB LoblaW :us: (BOB member since 2007-10-23)
