I’m currently looking on how to avoid creating several scheduled instances with a different value/prompt for each scheduled report.
Is there a way to use a list of values that can be automatically used in the prompt without any manual action?
If I have 200 unique values, I will need 200 generated/scheduled reports from the appropriate list of values.
Using a publication may work, depending on how you are distributing the reports.
Outside of that, you’ll probably need to look at building you own solution with the SDK or using a 3rd party tool like APOS Bursting Manager or Wiiisdom 360Cast.
