Scatter Graph
Hi to All,
I have to create a scatter graph that contains also :
  1. some vertical and orizzontal lines to separate in the same graph four zone. These zones are dynamically obtained from the data peinted in the graph
  2. some labels that describe the zones above created.
I’m no idea about it.
Can someone help me !
Thank’you in advance
dp78Asp (BOB member since 2009-09-21)
Welcome to B:bob:B!
Have you tried inserting some blank cells positioned relatively to your graph? You can type in whatever narrative you want, to describe your zones…
Ok , thankyou.
But referring to the first question, do you have some suggestions?
The line in the chart are dynamically determined.
so in a first extraction I can have:
and in asecond extraction I will have:
and so on
TNX !
Hi , I know what you want and it is bit complex to explain.
I have done the scatter graph Vertical and Horizontal lines in Deski with a workaround solution.
Here are the tips.
Have two Columns (this is to draw axis at Zero axis and you have to change these values with your real values)
Horizontal --------- Vertical
0 --------- 100
0 --------- 0
0 -------- -100 (this is negetive 100)
Now plot the points and sort them so that you will get Horizontal and Vertical lines.
You need to manually adjust the x and y axis so that they look like lines.
Robby (BOB member since 2004-02-11)
In 3.2 (3.1 with SP2), you can build scatter plots with WebI.
I use the XI 3.1 version. It’s possible also with this version?
TNX!
No. Not available until SP2 for 3.1.
[Moderator note - advertising post removed]
