Can anyone tell me the VBA Code to save and print a report by branches, e.g.: i have 10 branches in a country, 10 reports must be saved as pdf in a defined location and should print 10 different reports.
This might be very simple, but i am very new to BO & VBA.
How is your report formatted? You can use the ExportasPDF() method on a document object to save the whole REP for the same method on a report object to save only the one report tab. Depending on how things are laid out and how youāre going to dsitribute things, you probabaly have a lot of options.
You can do this in two ways. One is to create a report with each brances in seperate tab and then use the macro ExportAsPDF() to save it to different reports.
The other way is to use the field which is used for Branches as section in the report and then use the macro to save the report into diff PDFs.
Tell us which one you prefer and we can help you out.
Weāve exported entire documents into one PDF and entire reports into several PDFs, but Iām intrigued by your observarion that separate sections (in the same report?) could be saved to individual PDFs. How would you do that?
Raj
Hi Raj,
As you have mentioned, i would like to use the second way u suggestedā¦to use the field which is used for Branches as section in the report and then use the macro to save the report into diff PDFs.
Appreciate your efforts, please let me know how to do itā¦
Here is the Macroā¦In the macro āStateā is the variable that is placed in the section of the report. You can change that with whatever field you wnat to be in your report. The PDF files will be saved for different section values.
Option Explicit
Sub FilterAndExport()
Dim mydoc As Document
Dim myrpt As Report
Dim myFilterVar As DocumentVariable
Dim i, j, noOfReports, intNumChoices As Integer
Dim myFilterChoices As Variant
Dim strNextValue As String
'Active Document
Set mydoc = ActiveDocument
' Active (with focus) Report
Set myrpt = ActiveReport
' Put your variable (or query object) here
Set myFilterVar = mydoc.DocumentVariables("[b]State[/b]")
' find out how many values there are for the variable
intNumChoices = UBound(myFilterVar.Values(boUniqueValues))
' collect the number of choices in a variant variable
myFilterChoices = myFilterVar.Values(boUniqueValues)
For i = 1 To intNumChoices
' Get the variable value
strNextValue = myFilterChoices(i)
noOfReports = mydoc.Reports.Count
For j = 1 To noOfReports
Set myrpt = mydoc.Reports.Item(j)
' build filter
myrpt.AddComplexFilter myFilterVar, "=<[b]State[/b]> = " & """" & strNextValue & """"
' recompute the report
myrpt.ForceCompute
Next j
'Declare Directory Structure
Dim DocPDF_Dir As String
'Set Directory Structure
'DocPDF_Dir = "C:\Documents and Settings\Desktop\"
'Declare Filenames
Dim Document_Name As String
'Set Filenames
Document_Name = "2006" & "_" & strNextValue
'Distribute Files
ActiveDocument.ExportAsPDF (DocPDF_Dir & Document_Name)
Next i
' now, unless I can find a RemoveComplexFilter function, this line is used
' to invoke a filter that is always true.
myrpt.AddComplexFilter myFilterVar, "=(1=1)"
myrpt.ForceCompute
End Sub
Thanks very much for this, Iāve been using this code too!
Now Iāve been trying to implement this code in another report as well, but the variable Iām using there in the complexfilter is not a dimension (not a variable from the database), but itās a ādetail-variableā. Can this be done with such a complex filter as well?
What Iām trying to achieve is that for each 500 pages a new PDF is created. These files have to be printed but our facilities donāt want files bigger than 500 pages (printer doesnāt handle moreā¦).
Any help would be very much appreciated. This problem is giving me headaches :?
Koen
Edit: If I have to use the AddComplexFilter with a Dimension I could use it on the sections. In that case, I need several PDFās which hold 160 sections each. Could this be an option writing the macro? (Iām not really experienced using VBA yetā¦)
Hi - it looks like this code should do just what I need but I am having some trouble getting it to recognise my section variable. I have secyioned my tab on "Segment Lvl2(Query 2 with CurrUnv)ā but when I replace your bit of code with this
Set myFilterVar = mydoc.DocumentVariables(āSegment Lvl2(Query 2 with CurrLead)ā)
I get āCannot find the Variable by its nameā back from VB.
The report is using 2 data providers (thus the variable name) - I have tried variations on the name eg just Segment Lvl2, enclosing it in <> etc to no avail.
Any clues? Afraid my VB is not too crash hot so probably something simple I have done.
Assuming that you need to get to the inner most section of your report, try using this:
Dim objDoc As busobj.Document
Dim objDocVar As busobj.DocumentVariable
Dim objReport As busobj.Report
Dim objSection As busobj.SectionStructure
Dim strSectionMaster As String
Set objDoc = Application.ActiveDocument
Set objReport = objDoc.Reports.Item("<report name>")
Set objSection = objReport.GeneralSectionStructure
' find innermost section
Do Until objSection.IsTerminal
Set objSection = objSection.SubSectionStructure
Loop
'get variable name that the section is created on
strSectionMaster = objSection.Master.Name
I altered the VBA code above for an export to Excel.
I also added a Sub to the code in order to include a Picture (Companylogo for example) to the Top-Left of each Excel Sheet.
Unfortunatelly I receive the error: āmethod range of object _global failedā which is probably due to my code not being 100% solid (Iām not a dedicated VBA programmer). Maybe someone can enhance my code in order to operate more robuste.
Dim Doc_Dir As String
Doc_Dir = "<yourPath>"
'Declare Filenames
'Set Filenames
Document_Name = "<yourDocName>" & strNextValue
' Distribute Files
' PDF
ActiveDocument.ExportAsPDF (Doc_Dir & Document_Name)
' Excel
ActiveDocument.SaveAs (Doc_Dir & Document_Name & ".xls")
'Insert Company logo in Excel sheets
ExcelInsertPicture noOfReports, Doc_Dir, Document_Name
Next i
'myrpt.AddComplexFilter myFilterVar, "=(1=1)"
'myrpt.ForceCompute
End Sub
Private Sub ExcelInsertPicture(ByVal noOfSheets As Integer, ByVal DocPath As String, ByVal DocName As String)
' Define Excel attributes
Dim xlApp As Excel.Application, xlWB As Excel.Workbook, xlWS As Excel.Worksheet
Dim k As Integer
' Path to Picture
Dim pPath As String
pPath = "<yourCompanyLogoPath>"
Set xlApp = New Excel.Application
With xlApp
'Open Workbook
Set xlWB = .Workbooks.Open(DocPath & DocName & ".xls", ReadOnly:=False, Editable:=True)
'Loop through all Sheets
For k = 1 To noOfSheets
'Activate appropriate Sheet
Set xlWS = xlWB.Worksheets(k)
xlWS.Activate
'Insert picture in Sheet
xlWS.Pictures.Insert (pPath)
'Align picture Top-Left
With xlWS.Pictures
.Left = Range("A1").Left
.Top = Range("A1").Top
End With
Next k
End With
'Activate 1st Sheet before saving
xlWB.Worksheets(1).Activate
'Save and Close Workbook
xlWB.Save
xlWB.Close
Exit_Routine:
Set xlApp = Nothing
Set xlWB = Nothing
Set xlWS = Nothing
End Sub
the Error occurs on line:
.Left = Range(āA1ā).Left
It has to do with the Range that is not correctly defined⦠someone who can help me with this?
Probably an easier solution is to simply have the form open with a focus in your db window, then choose Print from the File menu . If you have a printer driver that prints PDF files, you can print an exact copy of this form in a PDF file.Or you can use the Microsoft Document Image Writer to generate a file. tif, or you can print the same thing on the paper with all printers installed on your computer.
