Saving Excel....
We are running 6.5.1
We’re having problems saving a report as Excel format from InfoView. All appears fine on screen, but when the report is opened as an Excel file the name and name identifier columns have disappeared.
If I run the same report in client and save as Excel from there, the names and name identifiers appear in the report (note in the version I’ve attached I’ve blanked the names column with x). Although, in this case all the line numbers have been replaced with -3.
Any ideas ?
saustin (BOB member since 2007-03-05)
Can anyone help with this ?
You’ve not attached your report…
Have you had a look at this ?
https://bobj-board.org/t/15226/13 its in the stickies section at the top of this forum…
Saving to excel generally sucks in BO… hoping its better in BOXI…
malc001 :new_zealand: (BOB member since 2005-09-26)
