Hello
I have a web intelligence report “Report A” created against one universe.
I would need users to access this report against 4 different servers which have exactly the same physical model (but obviously contain different data).
I have found a solution to create 4 different user IDs and have each ID use a different connection.
But is it possible have the same user with 4 “saved as” copies of the report, each of them saved with a different connection. i.e. save my “ReportA” in 4 different instances “ReportA-Database1”,…“ReportA-Database4”.
Is the connection management only possible at the level of the universe or the user id or is there a way to manage this at the report level?
apc75015 (BOB member since 2020-04-08)
(BOB member since 2002-08-29)
