system
1
hi,
in the view mode of the webi report under documents there is an option “Save as”.
On selecting it displays a window where the same report can be saved in some other folder or in new name
Now i want “Save as” option not to be displayed under the Documents menu…
What settings do we need to do in the CMC to remove “Save as” from Documents.
daffodils (BOB member since 2007-08-09)
system
2
Which version of BOXI you are using?
kanukula (BOB member since 2007-05-05)
system
3
i am using BO XI R3
system
4
There are three permissions that you need to give deny access for webi Intelligence Report type under access levels
- Save as PDF
- Save as Excel
- Save as CSV
