Has anyone used SAP Web Dispatcher as Loadbalancer for BO on Tomcat?
Any known issues or tips?
Jai
BusObjGuy2 (BOB member since 2005-05-27)
Jai
Were you able to successfully use SAP Web Dispatcher with BO XI 3.1? I’m doing a similar install.
Pfire (BOB member since 2008-05-22)
Hye ,
I’m getting an error "An error has occurred: A timeout error has occurred ’ while navigating Public folders through SAP web dispatcher . Were you guys able to do it ? PLease let me know your status . Thanks
Cynosure
cynosure (BOB member since 2011-10-05)
I had the same problem using IIS 7.5 and the solution was to lower the parameter ‘maximum worker processes’ to 1. Had something to do with more than 1 worker process breaking the ASP.NET ‘session state’.
Ricus (BOB member since 2011-10-05)
hye ,
Where can i find "maximum worker processes "property in TOMCAT ? I mean does tomcat have similar property . If yes , what and where . Thanks .
Cynosure
sorry, I’ve got no exprecience with using ‘SAP Web Dispatcher’ so can’t help you there, but since it had something to do with breaking the ‘session state’ I would look in that direction.
Did you achieve using SAP web dispatcher as loadbalancer for BO on Tomcat?
We need to install a high-availability solution for BO, so we thought of using SAP web dispatcher in order to balance load between the two CMS in a cluster.
Do you know where could we get some documentation about it?
Thanks in advance !
Eva
everdaguer (BOB member since 2012-04-16)
