SAP-Rapid-Marts: rf011q.aba to generate "FSItemText.dat
Hello Rapidmart Freaks
We run the Rapidmart 12.2 on SAP. Now we have the problem that SAP not generates the FSItemText.dat" in the “R3_FSHierItemTextCluster”
We run the start part of the function to generate the text in SAP. But we couldn’t test the generation of the file for output.
  1. How work this call of a external aba file exacttly?
  2. Is there any special right necessary on sap?
Beat Honegger
RF011Q.txt (2.0 KB)
beat77 :switzerland: (BOB member since 2008-04-29)
That’s a custom abap transform. So you should check if the path the ABAP transform is using actually point on the jobserver to a directory where you placed those files to.
https://wiki.sdn.sap.com/wiki/display/BOBJ/Custom+ABAP+Transform
Thanks Werner - We checked that, this is not the reason.
We got the Flow isolated run, but not in the whole RM-JOB, yet.
We will investigate further.
Beat Honegger
