SAP R3 Connectivity
Hi all!!
I’m asking for your help in order to solve an issue i’m having but i can’t figure it out.
I made a SAP Applications DataStore using Direct Download method as I need only to show that we can access SAP metadata and read the information there. I can Import tables & BAPIs.
I made a simpel DF with an ABAP DF within it, it validates ok and i can see the ABAP code generated.
When I run the Batch Job it gets stucked on the ABAP DF Step for a few minutes and after a while it returns an error saying that the credentials are not OK (Name or Password Incorrect, repeat logon).
Credentials are fine as they’re being used to import metadata.
Any ideas??
Thanks in advance
Astro :argentina: (BOB member since 2007-02-15)
I couldn’t check it yet but I think that R3 server can’t reach my PC with the Job Server running on it.
Just to check, is the GUI_DOWNLOAD writing directly on the job server using the string provided on the FileName parameter within the Data Transport on the ABAP DF output?
Thanks in advance!
Direct_download is a bad idea, it fails often, it is slow, it requires a full SAP GUI installed on the jobserver machine.
When you look at the generated ABAP, one parameter controls if the data should be written to a file or downloaded directly. If the latter, then once 1000 rows are collected, the ABAP does call the GUI_DOWNLOAD function module.
http://wiki.sdn.sap.com/wiki/x/dYU_E
http://www.sapdev.co.uk/abap/guifrontend/gui_download.htm
