SAP NW Portal and BOE SSO Integration using LDAP
Hello,
We have a Business Objects XI environment and SAP NW Portal that needs to be configured for SSO. The issue is that SAP NW Portal is configured to use a LDAP Authentication to login to the Portal hence if we use LDAP Authentication for BOE, we wont be able to achieve the SSO between Portal and BOE as importing users and having those roles in BOE is a pre-requisite for integration between BOE and SAP Portal.
Question here is how to leverage LDAP Authentication on BOTH SAP NW Portal and BOE but still be able to configure SSO between both Portal and BOE and also refresh data in a Business Objects Crystal/Webi report from any SAP system including ECC/BW.
Is there any product document / guidelines to achieve this?
Ravi
bocert09 (BOB member since 2009-09-04)
You can try following…
Enable SAP Authentication on BOE
Enable Trusted Authentication on BOE
Enable SNC between Portal and BOW
This would work if LDAP id and SAP user id are same.
AskMe_Dhirendra (BOB member since 2010-08-04)
