SAP Lumira 2.0 - crosstab sub-totals
Hi there
I am trying out Lumira 2.0 and I can’t find out to sum the columns in a cross-tab. This is such a a simple request that it must be available??? But I can’t find it anywhere :hb:
Can anyone help please?
SarahG :australia: (BOB member since 2005-08-22)
Would help if you specify which tool in Lumira 2.0 are you referring to ? Discovery or Designer?
katullus :us: (BOB member since 2009-08-21)
I’m using Disvovery.
well in lumira 1.31 its pretty simply; right click on the column > Total > More > and under ROWS select “Aggregation Total” and you’ll get a total at bottom of each column of a crosstab. I would imagine it’s similar in 2.0.
It wouldn’t surprise me, Lumira Discovery is currently half baked in my opinion (compared to other similar tools).
