SAP Integration Kit - New Product Key Code
We wish to apply a new product key code to SAP Integration Kit. We can’t do it in the CMC, not even the old oen is in there.
Where do we apply it?
Damocles :uk: (BOB member since 2006-10-05)
Damocles,
Run again the installation package. You will find an Upgrade option where you could apply your production license.
Javier Kuan
:reallymad:
javier.kuan :peru: (BOB member since 2008-02-29)
Javier,
is it the same for unix?
I need to set a new keycode for SAP Integration XI3.1.
tks,
Marlon
marlon.kotai (BOB member since 2006-02-01)
[quote:cdeca2e39c=“marlon.kotai”]Javier,
tks,
Marlon
[/quote]
Marlon.kotai,
I haven’t installed SAP Integration Kit in Unix. Try running ./install.sh of SAP Integration Kit and look for the upgrade option menu. Please tell us your results.
Javier
It’s nedded to edit the registry and change de keycode.
Hi, how they placed the new key in UNIX? :crazy_face: , When I run the installer again does not give me the Upgrade option … :hb:
KoRn_mAn :mexico: (BOB member since 2005-10-26)
Did you find a solution to this at all, I’m facing the same issue…
Shabbah :uk: (BOB member since 2009-12-02)
Hi Shabbah:
My solution was temporary, because I have the problem again, I asked to check my license to access data from SAP, the solution was through Crystal Reports License Manager, you put the license there, I no longer work for me, my system is Solaris 10… :hb:
To finalise an answer to this in case anyone else still can’t update the licence on Unix systems, see SAP note 1290756 - the file to update with the licence key is:
…/bobje/data/.bobj/registry/software/business objects/suite 12.0/sap/keycode/.registry
Chris.
