I am doing SAP HANA performance testing.
I used the testing file size as 1GB, 5GB, 10GB and etc.
In each file size, I tested different block sizes for Log and Data - I tried 4k, 16k, 64k, 1MB, 16MB and 64MB block size.
The result is:
- the file size (1GB, 5GB or 10GB) doesn’t bring much difference.
- The block size shows very different results: when the block size is less than 1MB, the IO performances are very poor - the Write IO is even poorer than Read IO; when the block size is more than 1MB, the IO performance improves signicifantly.
I was wondering why the block size may impact the IO so much?
And, if using block size less than 1MB, what factors can I change to improve the IO performance so that it’s comparable with that of block sizes more than 1MB?
Thanks!
jameszhjw (BOB member since 2013-07-25)
