SAP Design Studio: adjust data range
is it possible to adjust the data range inside SAP Design Studio? I have the following problem:
I get a lot of data by a query (Bex). For example: production output per week. So, the result looks like this:
Do i have to adjust the query or could i change the selection inside Design Studio? For example: Just show me the last 10 weeks based on the current week.
Robert1980 (BOB member since 2015-05-28)
You can set a filter on your datasource.
DS_1.setFilterExt("0FISCPER", "008.2014 - 03.2015");
To get only the 2 last month, you’ll need some code.
To get today’s date:
APPLICATION.getInfo().dateNowInternalFormat;
Another way is to use an exit client variable in your bex query (CMOD transaction).
Fylim (BOB member since 2015-08-20)
