Hello All,
We are trying to consume data from Web services, When we are using using
HTTP it was working perfectly, But when we are trying to use HTTPS we are facing the below error.
6308 6100 RUN-248005 2017-04-24 3:26:00 PM There is no response for the web service . Ensure that the network, web server, and service are running
6308 6100 RUN-248005 2017-04-24 3:26:00 PM properly. Also ensure that the service client call time out is set properly.
If we test HTTPS wsdl file SOPAUI it was working and if we paste this url in Internet Explorer i can see the XML. I have also place
HTTPS web services (which we got from Webservices Team)certificate in D:\SAP_BODS_INSTALL\Data Services\ssl\server.
If the documentation part it was mentioned to uncomment transportReceiver for https, But it was defulatly uncomment in DataServices SP8 vesion. Can anyone please help me on this…
Below is the axis2.xml
<!-- Set the suitable size for optimum memory usage when sending large attachments -->
<!--parameter name="MTOMBufferSize" locked="false">10</parameter-->
<!--parameter name="MTOMMaxBuffers" locked="false">1000</parameter-->
<!--parameter name="EnableMTOMServiceCallback" locked="false">true</parameter-->
<!--parameter name="attachmentDIR" locked="false">/path/to/the/attachment/caching/dir/</parameter-->
<!--parameter name="MTOMCachingCallback" locked="false">/path/to/the/caching_callback</parameter-->
<!--parameter name="MTOMSendingCallback" locked="false">/path/to/the/sending_callback</parameter-->
<!-- Enable REST -->
<parameter name="enableREST" locked="false">true</parameter>
<!-- Uncomment following to persist op_ctx, useful with RM -->
<!--parameter name="persistOperationContext" locked="false">true</parameter-->
<!--if you want to extract the service archive file and work with that please uncomment this-->
<!--else , it wont extract archive file or does not take into consideration if someone drop-->
<!--exploded directory into /service directory-->
<!--<parameter name="extractServiceArchive" locked="false">true</parameter>-->
<!-- Message Receivers -->
<!-- This is the Deafult Message Receiver for the Request Response style Operations -->
<!--messageReceiver mep="INOUT" class="axis2_receivers"/-->
<!-- Transport Ins -->
<transportReceiver name="http" class="axis2_http_receiver">
<parameter name="port" locked="false">6060</parameter>
<parameter name="exposeHeaders" locked="true">false</parameter>
</transportReceiver>
<transportReceiver name="https" class="axis2_http_receiver">
<!--transportReceiver name="tcp" class="axis2_tcp_receiver">
</transportReceiver-->
<!-- Transport Outs -->
<transportSender name="http" class="axis2_http_sender">
<parameter name="PROTOCOL" locked="false">HTTP/1.1</parameter>
<parameter name="xml-declaration" insert="false"/>
<!--parameter name="Transfer-Encoding">chunked</parameter-->
<!--parameter name="HTTP-Authentication" username="" password="" locked="true"/-->
<!--parameter name="PROXY" proxy_host="127.0.0.1" proxy_port="8080" proxy_username="" proxy_password="" locked="true"/-->
</transportSender>
<!-- Uncomment the following with appropriate parameters to enable the SSL transport sender.
Also make sure that the appropriate transport receiver is enabled above.-->
<transportSender name="https" class="axis2_http_sender">
</transportSender>
<!-- <parameter name="SERVER_CERT">/path/to/ca/certificate</parameter>
<parameter name="KEY_FILE">/path/to/client/certificate/chain/file</parameter>
<parameter name="SSL_PASSPHRASE">passphrase</parameter>
<!-- Uncomment this one with the appropriate papameters to enable the TCP transport Sender-->
<!--transportSender name="tcp" class="axis2_tcp_sender">
<parameter name="PROTOCOL" locked="false">TCP</parameter>
</transportSender-->
<!-- Global Modules -->
<!-- Comment this to disable Addressing -->
<module ref="logging"/>
<module ref="addressing"/>
<!--module ref="rampart"/-->
<!--Configuring module , providing paramters for modules whether they refer or not-->
<!--<moduleConfig name="addressing">-->
<!--<parameter name="addressingPara" locked="false">N/A</parameter>-->
<!--</moduleConfig>-->
<!-- Phases -->
<phaseOrder type="inflow">
<!-- System pre defined phases -->
<phase name="Transport"/>
<phase name="PreDispatch"/>
<phase name="Dispatch"/>
<phase name="PostDispatch"/>
<!--phase name="Security"/-->
<!-- End system pre defined phases -->
<!-- After PostDispatch phase, module or service author can add any phase as required -->
<!-- User defined phases could be added here -->
<!--phase name="userphase1"/-->
</phaseOrder>
<phaseOrder type="outflow">
<!--system predefined phase-->
<phase name="MessageOut"/>
</phaseOrder>
<phaseOrder type="INfaultflow">
</phaseOrder>
<phaseOrder type="Outfaultflow">
</phaseOrder>
vinay
vinay.sapds (BOB member since 2011-05-16)
