BusinessObjects Board
SAP Dashboard 4.1 and Xcelsius
I know lot of people ask the same question. I tried looking on the forum but did not find any resolution.
How can i integrate Sharepoint with SAP Dashboard (4.1) using open document. When user click Dashboard on sharepoint it should open swf file without asking credential.
I guess we need to integrate both using SSO (LDAP or Active Directory).
noreports :us: (BOB member since 2011-06-17)
I’m not sure, but it sounds like you are asking about 2 different issues.
“…Sharepoint should open swf file without asking credentials” This depends on what you are using for your connectivity option to load data into the dashboard. What connectivty option are you using? And which version (XI 3.x or 4.x )?
OpenDocument is an http call which can be used within a dashboard to launch a BusinessObjects report and pass parameters from the report.
~Roxanne P
Sr BI Consultant
Infosol
RoxanneP :us: (BOB member since 2006-08-07)
