system
1
Hi BODS Experts
We are loading flat file data in to BW 7.0
Is it correct that only BW 3.x Infosources can be used for transfer structures on DS side as target?
Why BW 7.0 Infosources cannot be used with DS 4.0 ? Is it possible ?
Thank you
softsys
(BOB member since 2005-05-13)
system
2
Actually DS 4.0 does support that, even 3.2 has the code inside. The problem is, BW 7.0 has no API (BAPI/RFC) for that, only BW 7.3 got it finally.
Werner Daehn
(BOB member since 2004-12-17)
system
3
Hi Werner, those that mean the is no way to load data into bw 7.0 using bods?
Extreamrav
(BOB member since 2011-08-23)
