SAP BODS - SAP ECC Connection Setup & Datastore Creation
Dear All,
I’m following the guide on this link http://scn.sap.com/docs/DOC-36374 in order to connect SAP BO DS on ECC. Unfortunately I’m stopped because on my installation file K900086.R63 is missing…
Where I could find this file on SAP Portal ?
Best Regards,
MJ
:wave: :wave: :wave:
zavatta_fighter (BOB member since 2005-05-10)
This file is in
%LINK_DIR%/admin\R3_Functions\transport\
where the LINK_DIR is your installtion directory
Dear ganeshxp,
is strange because on this directory I have only these files :
       1. K900025.E01
       2. K900200.S08
       3. R900025.E01
       4. R900200.S08
       5. readme
Best Regards,
MJ
I should have asked this first. Which version of Data services is this?
Also, goto the SAP Supplement for your version and you will have the Transport Number on it. These files are nothing but SAP Transports
Dear ganeshxp,
My DS version is : DS40 sp3
Could you give me the link of SAP Supplement… or otherwise, How I can import the transport file(K900086.R63) on DATA Services folder from SAP ECC ? There is any guide ?
Best Regards,
