SAP BODS installation hangs at "Uncaching Deployment Un
Hi gurus, here is as the title says. I have encountered this issue while installing SAP BODS 4.2 SP9 (sorry I can’t fit that at the thread title). Basically the installation will push through until that point and it seems to stay there. Looking at the Control Panel will list down SAP BODS and all the other applications associated to SAP BODS (Designer, etc.) were present and accounted for when I looked for them in the Start Menu. Note that this is a fresh machine and the only other application I installed there was IPS 4.2 SP4, where the same thing happened. I let it sit or almost over a week and it did not proceed to the last screen of the installer.
I tried searching the net and I only saw that this was supposedly an Anti Virus issue (turn it off), but there’s no AV Software. How do I test if DS Installed properly?
hueysantiago (BOB member since 2015-08-03)
Small update:
I haven’t closed the installation window and it’s still stuck at “Uncaching Deployment Units”. I managed to launch DS Manager, and log in to the default repository. I also managed to log in to the DS Management Console. Looks like everything is working fine so far, but I am still unsure as to what the longer-term impact is gonna be.
