SAP BODS debugger not working from remote DS designer
Hi ALL,
Error Log:
5484 11552 RUN-058012 6/10/2015 1:42:52 PM |Session testJobDebug
5484 11552 RUN-058012 6/10/2015 1:42:52 PM Access Server address XXX.XXX.XXX.173:5001 either is invalid or did not respond to the connection request. A valid address must
5484 11552 RUN-058012 6/10/2015 1:42:52 PM be provided on the command line used to start this process in order to complete the requested command. Following error was
5484 11552 RUN-058012 6/10/2015 1:42:52 PM received while listening for client connections:‘XXX.XXX.XXX.173:5001:RWSocketError: in RWSocket::connect: TIMEDOUT’.
5484 11552 RUN-058012 6/10/2015 1:42:52 PM Stopped listening for new connections. (BODI-40)
5484 11552 RUN-058012 6/10/2015 1:42:52 PM received while listening for client connections: ‘XXX.XXX.XXX.173:5001:RWSocketError: in RWSocket::connect: TIMEDOUT’.
DEBUGGER PORT(5001) WE ARE ABLE CHANGE USING BELOW OPTION
DS DESIGNER\TOOLS\OPTIONS\INTERACTIVE DEBUGGER PORT : 5001
NOT SURE WHY BATCH JOB IS CONNECTING TO ACCESS SERVER IN DEBUGGING MODE AND HOW TO CONFIGURE ACCESS SERVER IP FOR REMOTE DS DESIGNER?
Thanks in Advance!!
veeru812 (BOB member since 2013-06-19)
Are you sure the port 5001 open between the DS server, and the remote designer workstation.
amuh10 :uk: (BOB member since 2012-04-11)
