I know I have asked this question before but has anyone figured out how to just display the footer on the a table of data…
Any help/direction is appreciated
thanks
Sims
Sims786 (BOB member since 2006-04-04)
thanks
Sims
Do you mean keeping footer in place of Header?
Zaif
zaif235 (BOB member since 2010-06-15)
I removed the Header by unchecking the check box in the Table Properties, Show table headers, got the body cells as blank by deleting the object formula in the body cell and in the footer I wrote the formula as =sum([Measure]). I wanted to suppress the body cells height as 0px, but the minimum is 4px.
M H Mohammed (BOB member since 2010-06-16)
why not just use a string of blank cells? You can get the same values you would in a footer by using correct calculation contexts/sectioning.
rbacon (BOB member since 2011-02-03)
Point in what rbacon said. Or you can even try remove table headers by un checking Show table headers and put the formula for the summary from footer into the body cell, that way it has only one row.
I only found this out today:
it is not clear to me, however, why this feature is not available in table properties, but only via this button.
mirko
mirko (BOB member since 2002-08-21)
mirko,
I am having a ‘funny’ issue
Found the ‘show/hide fold-unfold toolbar’ button, but it is only working in edit-mode.
In normal-mode there is also the same button, but it only adds a grey field on the left side of the report…that’s all
Any ideas?
Johan
JdVries (BOB member since 2006-02-06)
All,
I’ve found out where the button is for in normal-mode (view-mode)
It folds/unfolds sections instead of breaks.
Johan
It also folds/unfolds Breaks.
But you have to select the data table that contains the Break object for the fold/unfold arrows to appear.
jhbrogdenjr (BOB member since 2011-04-19)
jhbrogdenjr,
That is what I suspected…but it doesn’t work for me
Question: how do you select a table/block in view-mode?
Johan
All,
Found it!
Folding/Unfolding on breaks break works only in ‘interactive’ view-mode…not in ‘web’ view-mode.
Maybe I should RTFM
Johan
