system
June 27, 2016, 7:20am
1
Hi Board members,
since today our BO DS system receives the following message when trying to connect via Salesforce adapter:
We’re using the following URL to acces the Salesforce adapter:
BO DS Version:
Designer: 14.1.3.875
JobServer: 14.1.3.875
JobEngine: 14.1.3.875
Repository: 14.1.1.0000
Question:
How can we change the Salesforce Adapter that it will use TLS 1.1 or higher?
barthodo (BOB member since 2012-04-18)
system
June 27, 2016, 10:09pm
2
We are facing same issue, have you found any solution?
Rajesh Kolli (BOB member since 2009-10-30)
system
June 28, 2016, 1:12am
3
Hello,
We have the same issue on our system. Has anyone found a solution yet?
update:
I found this on the SAP Support portal
https://launchpad.support.sap.com/#/notes/2266936/E
( 2266936 - Salesforce TLS Issue: Unsupported record version )
Hope this helps.
kent
kmamalias (BOB member since 2016-02-17)
system
June 29, 2016, 8:31pm
4
for DS 4.2 you can change the Adapter JRE to 1.8, check the following KBA
2275588 - How to update Data Services Adapter JRE to 1.8
you can try this for DS 4.1 also, but I am not sure if everything will work fine or not, give it a try, for DS 4.1 you can use the JRE 1.8 that is on your system (SUN/Oracle JRE)
Hi manoj_d ,
Thanks for the reply. We already have java version 1.8 , but is still unable to connect to SFDC Stg
what is the OS on which DS Adapter job server is running ?
did you change the JRE version to JRE 1.8 under %LINK_DIR%\ext\jre ?
system
July 5, 2016, 11:44am
7
Hello All,
We are also facing same issue.
Could anyone tell me how to fix this issue.
Vasuda.
Vasuda Peddi (BOB member since 2016-07-01)
following the instructions in the SAP note 2275588 - How to update Data Services Adapter JRE to 1.8
Hello manoj_d ,
Our connection to SFDC Stg is okay now. I upgraded the JRE for SAP DS to version 8. Thanks for the input.
I hope this would help others facing similar issue.
kent
system
July 18, 2016, 8:19pm
10
Hi kmamalias/manoj_d
Can you please let me know where you have downloaded the SAP JRE 1.8.
I am unable to find it in the Downloads section of Service Market Place.
Rakesh
rakeshnarne (BOB member since 2010-12-21)
system
July 18, 2016, 8:48pm
11
go to http://service.sap.com
click on download
in the search box on the top, enter SAP JRE 8.1
you will get a result under Select Next Category, click on that, and you will see the download
check the attached image
jre81.zip (59.0 KB)
system
August 30, 2016, 6:30am
12
Has anyone experience with changing the JRE from 1.6 to 1.8 in DS 4.1?
Is it working without issues?
We don’t have a sandbox / isolated system where we can just try this…
system
August 31, 2016, 4:29am
13
you can try on your 4.1 env, you don’t need a longer downtime, it’s not going to impact anything else
the %LINK_DIR%\ext\jre is used by adapters only
use the Sun/Oracle JRE 1.8
let me check if I can find DS 4.1 env to quickly test this
if you run into any issue, let me know
