Hello Experts,
I am currently in the process of running the Sales Rapidmart Data Model Job on an Enterprise Evaluation Version of Ms SQL 2008 R2 DB.
The behavior I am experiencing is the following; When executing the Sales Rapidmart Data Model Job, the job will create the first 7 tables in the Query Qry_Create_Table found in the Dataflow DF_TableCreate_SAP and the WF_Tablecreate_SAP workflow.
After creating the first 7 tables, and completing the creation of the ACTIVITY_HIER_BAD table, the dataflow will fail to create the ACTIVITY_HIER_HZ table and will not create any other tables. The Job essentially fails once it reaches the point of creating the ACTIVITY_HIER_HZ table and does not move from there.
Other Behavior i’ve experienced and noticed is that the DF_TABLE_CREATE_SAP job will run without ever erroring out, in essence, it will create the first 7 tables, and at times will generate an error along the lines of "Syntax Error Near ‘,’ " (not very descriptive) and at other times the job will just stall and appear to be running with no errors at all.
Has anybody experienced any of these behaviors? if so, what was done to correct the behavior?
Any and all help will be appreciated.
Thank You.
CTX_CHI (BOB member since 2014-01-03)
