Hello All,
The Initial Load on the DEV server failed with an error ‘Time Limit exceeded’ while executing the DF_SalesOrderStage_SAP dataflow. To resolve this I changed the ‘Execute in Background’ to Yes and executed the job, after which I get the below error message
4640 8220 R3C-150605 3/23/2013 7:04:52 AM |Data flow DF_LanguageEnable_SAP
4640 8220 R3C-150605 3/23/2013 7:04:52 AM The SAP job was canceled for host < >, job name <R3_LanguageEnable 03/23/13 07:04:37>, job count <07043700>, job log from SAP <
4640 8220 R3C-150605 3/23/2013 7:04:52 AM 23.03.2013 07:04:37 Job started
4640 8220 R3C-150605 3/23/2013 7:04:52 AM 23.03.2013 07:04:37 Step 001 started (program ZW04640001, variant &0000000000000, user ID BIADMIN01)
4640 8220 R3C-150605 3/23/2013 7:04:52 AM 23.03.2013 07:04:37 Error at OPEN ‘F:\usr\sap\DEV\SYS\global\ftproot/LangEnable.dat’ (check file)
4640 8220 R3C-150605 3/23/2013 7:04:52 AM 23.03.2013 07:04:37 Job cancelled after system exception ERROR_MESSAGE
4640 8220 R3C-150605 3/23/2013 7:04:52 AM >.
9964 9384 R3C-150605 3/23/2013 7:04:52 AM |Data flow DF_LanguageEnable_SAP
9964 9384 R3C-150605 3/23/2013 7:04:52 AM The SAP job was canceled for host < >, job name <R3_LanguageEnable 03/23/13 07:04:37>, job count <07043700>, job log from SAP <
9964 9384 R3C-150605 3/23/2013 7:04:52 AM 23.03.2013 07:04:37 Job started
9964 9384 R3C-150605 3/23/2013 7:04:52 AM 23.03.2013 07:04:37 Step 001 started (program ZW04640001, variant &0000000000000, user ID BIADMIN01)
9964 9384 R3C-150605 3/23/2013 7:04:52 AM 23.03.2013 07:04:37 Error at OPEN ‘F:\usr\sap\DEV\SYS\global\ftproot/LangEnable.dat’ (check file)
9964 9384 R3C-150605 3/23/2013 7:04:52 AM 23.03.2013 07:04:37 Job cancelled after system exception ERROR_MESSAGE
9964 9384 R3C-150605 3/23/2013 7:04:52 AM >.
I do not get this error message if I change the ‘Execute in Background’ to No . The ‘Working Directory on SAP server’ is set to ‘F:\usr\sap\DEV\SYS\global\ftproot’ and the ‘FTP host Working Directory’ is ‘.’
I manually logged in to SAP server using FTP and can see the LangEnable.dat file there, tried to run the Job after deleting the LangEnable.dat file still the same error.
Any help on this is appreciated
Thank You
Ranjit
ranjit.krishnan (BOB member since 2008-11-11)
