RunningSum Reset Issue
Hello All,
We just did a FP3.6 upgrade (XI R3 SP 3).
I have a report using runningsum function that does a break on a dimension called [Break ID] and it used to work without the [Break ID] dimension being in the table. Now with the upgrade it needs to be present.
The report consists of two queries. The revenue and other dimensions are part of one query. The Break ID and other dummy dimensions used for sorting purposes are in the second query. I use merge dimensions to combine the data.
As of yet I have not found a work around for this. Any suggestions?
I have to convert the table to a chart, if it was not for this I would have just used formatting to hide the Break ID.
honkeyhindu (BOB member since 2007-03-29)
