RunningCount does not work with sections
I have a running count:
Machine Count Running Count
21 1 1
21 1 2
23 3 5
24 1 6
24 2 7
24 3 10
When I now section by machine, I get this
21
Count Running Count
21 1 1
21 1 2
Count Running Count
23 3 5
As can be seen, the running count does not reset at the start of each section. Why not?
Running Count= runningcount(OID)
(Where OID is unique ID for each row)
fghs_1987 :uk: (BOB member since 2008-01-02)
Hi Joseph
I think you need to specify the section object (eg machine) in the parameters to RunningCount.
See the section on RunningCount in here for the full syntax. This guide is for WebI, but the syntax maybe similar for Deski.
Cheers, Sandi
SandiR :uk: (BOB member since 2004-12-20)
I tried this:
runningCount(OID) In (Machine)
Still no change.
Is this a bug?
Hi again Joseph
Can you try …
 RunningCount(<OID>;<Machine>)
This seemed to work for me
Sandi that worked great!! Many thanks.
