I need a total for only certain records, which is easy enough to do. My problem is I need to put that total in first group header. I can see my total in the report footer, but it always shows $0 in the header.
I’m using Crystal XI R2
Here’s what I have tried so far.
Formula:
whilereadingrecords;
global currencyvar BillableAmount;
if {Command.Billing Status}=“Billable” then
BillableAmount := BillableAmount + {Command.ReimbursementAmount} else
Running total with the following condition.
Another solution to this is insert the report into iteself (in the group header) as a subreport. Link the subreport on the value that the groupheader is based on. Then use a shared variable to get the runningtotal out of the subreport into the main report. Then suppress the subreport (as long as shared variables now work between a main and suppressed subreport). If not, make the subreport really small…
