system
#1
I am running supervisor setup (BO 6.5.1) and I was successfully able to create the universe and supposedly even the bomain.key.
When i looked at the path - which is the default path ->LocData under my BO folder, I couldn’t find it.
I thought of recreating it by using the safe recovery option and when I try to do that I get the message -> 'There is no valid connection (ADW0003).
- Can anyone help me with the abpve issue
- Also, how can I create a second reserve password for logging into supervisor?
Please help.
User@BO (BOB member since 2012-07-23)
system
#2
Did you create a connection to connect to Security Domain ? Do you have all the 3 domains under one schema ??
BO_Chief (BOB member since 2004-06-06)
system
#3
Thanks for replying.
I am now able to access the Administartor console and login too , but only through the BO console.
When i try these urls -
http://localhost/wiadmin
http://localhost/wiasp
- I get page cannot be FOUND.
Any help is appreciated
system
#4
Options tried -
I unchecked the friendly message option in IE and i see the message - Bad Request (Invalid hostname)
here are the steps I have ensured -
- Enabling the parent paths
- Setting - Allow scripts and executables
- Enable session state
- restart server
No luck yet! Any pointers?
Please let me know
system
#5
I am not able to see the login page, however on clicking of login - I get the error -
The Business Objects server is not ready. (Error: INF 00105).
I checked for the WILogin server - the authentication mode is set to BO. I do not see any options.
- How can I see the different options and should I change to it to any other mode?
- What needs to be done to resolve the issue -
Any help is highly appreciated.
