Running More Than One Report With The Same Prompts
          On a
 Lee,
 You would do it exactly as you implied...with scripting.  Set up a
 script which gives the user a text box into which they would enter the
 customer number.  Capture this entry as a variable, and then just
 insert it into each BOcondition value for the customer prompt for each
 query.  There should be examples of this type of thing in the
 Developer's Guide.
 Jason Beard
How would I setup a series of about 8 Business Object Reports which have
similar prompts to run at the same time on a client PC. The results for
all reports would come back to the individual PC. Is scripting a
possibility?
We have users who want to run all the reports (about 7-8 reports) at once
for the same customer. They want to be able to walk away and then just
come back when all of them are done. Any ideas?
