Running Meta data integration on ERP fails with code 4
Hi all,
after successfully reading meta data from HANA, BW and BO 4, I try to set up a integrator source connect to SAP ERP, but it always fails and I can’t tell why.
Do you have any advice?
Thanks in advance,
B.
The protocol says (sorry, some parts are in german):
[I] 2016-05-24 10:10:11.831 [MMSAPIntegrator][main] Processed [84.000] of [97.689] DataDmain. (SEM-10020)
[I] 2016-05-24 10:10:12.371 [MMSAPIntegrator][main] Processed [86.000] of [97.689] DataDmain. (SEM-10020)
[I] 2016-05-24 10:10:12.896 [MMSAPIntegrator][main] Processed [88.000] of [97.689] DataDmain. (SEM-10020)
[I] 2016-05-24 10:10:13.436 [MMSAPIntegrator][main] Processed [90.000] of [97.689] DataDmain. (SEM-10020)
[I] 2016-05-24 10:10:13.953 [MMSAPIntegrator][main] Processed [92.000] of [97.689] DataDmain. (SEM-10020)
[C] 2016-05-24 10:10:14.009 [MMSAPIntegrator][main] Aufzeichnung der Cache-Statistik wurde am 2016-05-24 10:10:13.977 gestartet.
[C] 2016-05-24 10:10:14.009 [MMSAPIntegrator][main] Cache name=MetadataManagerConfiguration.1 count=2 avgGetTime=0.0 totalHits=1 totalMisses=3 inMemoryCount=2 inMemoryHits=1 onDiskCount=0 onDiskHits=0 evictions=0
[C] 2016-05-24 10:10:14.009 [MMSAPIntegrator][main] Cache name=MetadataManagerConfiguration.33 count=92151 avgGetTime=2.84874E-4 totalHits=368584 totalMisses=9 inMemoryCount=10000 inMemoryHits=368584 onDiskCount=82151 onDiskHits=0 evictions=0
[C] 2016-05-24 10:10:14.009 [MMSAPIntegrator][main] Cache name=System count=0 avgGetTime=0.0 totalHits=0 totalMisses=0 inMemoryCount=0 inMemoryHits=0 onDiskCount=0 onDiskHits=0 evictions=0
[C] 2016-05-24 10:10:14.010 [MMSAPIntegrator][main] Aufzeichnung der Cache-Statistik wurde am 2016-05-24 10:10:13.977 abgeschlossen. (COR-10437)
[E] 2016-05-24 10:10:14.049 [MMSAPIntegrator][main] Index: 14, Size: 14
[E] 2016-05-24 10:10:14.050 [MMSAPIntegrator][main] java.lang.IndexOutOfBoundsException: Index: 14, Size: 14
at java.util.ArrayList.RangeCheck(ArrayList.java:547)
at java.util.ArrayList.get(ArrayList.java:322)
at com.sap.icc.integrator.ecc.collector.AbstractCollector.preProcessObject(AbstractCollector.java:87)
at com.sap.icc.integrator.ecc.collector.AbstractCollector.processObjects(AbstractCollector.java:65)
at com.sap.icc.integrator.ecc.collector.AbstractCollector.process(AbstractCollector.java:40)
at com.sap.icc.integrator.ecc.collector.Controller.run(Controller.java:131)
at com.sap.icc.integrator.ecc.MMSAPIntegrator.integrate(MMSAPIntegrator.java:301)
at com.bobj.mm.integrator.Integrator.execute(Integrator.java:200)
at com.bobj.mm.utility.Utility.runExecute(Utility.java:448)
at com.bobj.mm.core.Main.run(Main.java:1265)
at com.bobj.mm.core.Main.main(Main.java:242)
[C] 2016-05-24 10:10:14.127 [MMSAPIntegrator][BatchExecuteThread-8] Für 1 INSERTS und 0 DELETES wurde ein Rollback aus Tabelle dbo.MMT_Data_Group durchgeführt. (COR-10138)
[C] 2016-05-24 10:10:14.133 [MMSAPIntegrator][BatchExecuteThread-9] Für 1 INSERTS und 0 DELETES wurde ein Rollback aus Tabelle dbo.MMT_Actor durchgeführt. (COR-10138)
[C] 2016-05-24 10:10:18.128 [MMSAPIntegrator][BatchExecuteThread-7] Für 92.001 INSERTS und 0 DELETES wurde ein Rollback aus Tabelle dbo.MMT_Data_Element durchgeführt. (COR-10138)
[C] 2016-05-24 10:10:18.132 [MMSAPIntegrator][main] Batch-Sperre wurde aufgehoben. (COR-10215)
[E] 2016-05-24 10:10:18.135 [MMSAPIntegrator][main] Hilfsprogramm mit Code 4 fehlgeschlagen. (COR-10020)
[I] 2016-05-24 10:10:18.137 [MMSAPIntegrator][main] Ausführung am 2016-05-24 10:10:18 abgeschlossen. (COR-10015)
[I] 2016-05-24 10:10:18.139 [MMSAPIntegrator][main] Verstrichene Zeit: 0:44.649 [Min:Sek:MS]. (COR-10084)
[C] 2016-05-24 10:10:18.159 [MMSAPIntegrator][main] SQL SELECT statements: count=2, rows=2, bytes=299, msec=1 for table Actor. (COR-10849)
[C] 2016-05-24 10:10:18.159 [MMSAPIntegrator][main] SQL UPDATE statements: count=3, rows=0, bytes=0, msec=31 for table Actor. (COR-10851)
bastula :de: (BOB member since 2008-09-22)
what is the complete version of IS ? this was fixed in SP03 or SP04
