Running a report with LOV value 'ALL'
I have modified the LOV of an object to include ‘ALL’ in the list of values. the code is:
SELECT TABLENAME.COLUMNNAME
FROM
TABLE
UNION
SELECT ‘ALL’ FROM DUAL
While running the report, if i select ALL from LOV, there is no data returned. How do i tell BO that when i select ALL from LOV, it should include all the values associated with the object.
raovala (BOB member since 2004-11-01)
This item has been asked/discussed a lot. Therefor it ended up in de designer FAQ: https://bobj-board.org/t/15227/2
jobjoris :netherlands: (BOB member since 2004-06-30)
