system
July 10, 2013, 10:11am
1
i have a question regarding RowIndex() function. When i add it to a table, it gets stretched.
For example i have a table where i get months from create date - MonthNumberOfYear([Create Date])
it displays values from 1 to 12. Now if i put RowIndex() in another collum in this table i get it stretched to 500000 rows… why it doesnt simply display values 1-12? (or 0-11)
Iscario (BOB member since 2012-09-03)
system
July 10, 2013, 10:15am
2
You’re confusing rowindex() with Linenumber().
Rowindex() returns the row from the database , e.g. the source data.
Use linenumber() if you want the line in a report block.
HTH
NMG
mcnelson (BOB member since 2008-10-09)
system
July 10, 2013, 10:31am
3
… ok thx.
There is no mentioning about this in either Webi or Documentation…
Thansk once again
system
July 10, 2013, 10:47am
4
It’s in the “Web Intelligence Formulas, Functions & Calculations ” document, but it’s a bit opaque:
RowIndex
Description
Returns the number of a row
Function Group
Misc
Syntax
integer RowIndex()
Notes
Row numbering starts at 0.
RowIndex returns #MULTIVALUE when placed in a table header or footer.
Examples
RowIndex returns 0 when it appears on the first row of a table.
This topic addresses the difference between Rowindex and Linenumber a bit better:
We have a table, in which we want to display the row number as a first column in a table. Tried using LineNumber() and rowindex() functions, but didn’t help. Appreciate your inputs.
Ganesh
gan_j (BOB member since 2007-02-19)
HTH
NMG
