Row values as Column header(s)
I have a spreadsheet style report for the most part it was plain and easy.
Now, I need to interject additional objects to the report but the request is to make the objects act as Column headers and within each column header there is a row value based on another object!
Getting confused on trying to do this, first thought of Crosstab but can’t get it to align correctly. Next tried to section it out but users don’t want to see this as the rows for each section can and will be duplicated over and over for each section.
Running out of ideas so am reaching out to the gurus here to lend a hand with prior reporting experiences similar.
To visualize this is what it needs to look like…
Column…Column…Column(Object value)…Column(Object value)
obj…obj…object(based on another object)…
Crazy enough so hope I am explaining it right!? :crazy_face:
ystu15 (BOB member since 2011-02-10)
you can use variables as dynamic column names like
column1
column2
column3
fill this variables with your if-then-else logic.
result of the variables are the real name/content of the column
n8aktiv :de: (BOB member since 2018-12-29)
I tried that, I got the dreaded #MULTIVALUE
if there are ambiguous values, then you have to made it unique in your formula with min(), max(), first(), last()
and/or with exact calculation-context
There may be more than one value so if there are they would need to appear in subsequent columns across the report.
Not only that within each of those columns there may be a value result from another field!
This makes it a more intense report to create :crazy_face: :blue: :hb:
The report should look like this with the var_StructCategory values going across as COLUMN Headings.
Underneath those Categories I need to insert other values that relate to each of the StructCategories
I know it may be easy for some but keep getting MULTVALUES or appearance not what I want…
I remember seeing this but its been so long ago I am having recollecting problems with out to do it without getting the MULTIVALUE error.
Again, I can add a the column to the vertical report but when I try to make it part of the header row MULTIVALUE… :hb: :hb:
toscajo@yahoo.com
the example does not show us your problem.
this is only some simple data that can easy be converted into crosstab :frowning:
first try adding all fields into a vertical table and check if everything is displayed correctly before doing some crosstab.
then build a crosstab from scratch, step by step adding fields.
if something is going wrong, edit the formula of this field or try to move the value/formula to a variable.
