Hello. You can force a link between the GL_CODE_COMBINATIONS table and any
other required table. I have been doing this at an object level in
Designer. For example, say SEGMENT3 exists on the GL_CODE_COMBINATIONS and
SEGMENT5 exists on a table called GL_OTHER. Your row level restriction will
be WHERE GL_CODE_COMBINATIONS.SEGMENT3 = ‘0500’ as it currently is. In
Designer, select the object which corresponds to SEGMENT5 of GL_OTHER. In
the edit properties window, select the definition tab. Click on the tables
button at the bottom right. The GL_OTHER table should be highlighted. Hold
down the control key and also select the GL_CODE_COMBINATIONS table. This
will force the join between the GL_OTHER and GL_ CODE_COMBINATIONS tables
whenever SEGMENT5 and no object from the GL_CODE_COMBINATIONS table is
selected. I also don’t know if you are applying row restrictions from
within Designer (at the object level) or within Supervisor (at the class
level) but you will have more success in the long run if row restrictions
are applied using Supervisor. Hope this helps.
Best regards,
Crystal Golding
Senior Systems Analyst
Management Information Section
University of Queensland
Brisbane Australia 4072
E-mail: c.golding@mailbox.uq.edu.au
Web: www.mis.jdstory.uq.edu.au
Phone: +61 7 336 57289
Fax: +61 7 336 58202
